Old 03-11-2009, 08:57 PM
big white bufflo big white bufflo is offline
codes help 92 sho
I have code 114, act/Iac/vat out of range what will cause this and 225, nok sensor not detected NEED HELP
Old 03-11-2009, 09:43 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: codes help 92 sho
Have you verified the IAC and knock sensors are connected? These may both have been disconnected/removed when changing the CKP sensor as you've posted elsewhere. Make sure everything, including engine grounds, got hooked back up properly. Also, when you replaced the ECM did you replace it with the same part number?
-Rod
Old 03-12-2009, 07:08 AM
shorod this car i have had it since last year the guy is in no hurry to get it back i have not test driven the car yet with the new pcm but with old one it did the misfire after all the plugs,wires,cps, were changed now after reading on a RCM parts web it could be the cam sensor so all those point are valet i will look into them today now i have communication with this car we can go forward to get it fixed yes the pcm is the same part number i will keep this up dated I LOVE THIS FORUM AND ENJOY HELPING OTHER OUT ON THIS PLACE with there car troubles thank for your imput that why i came here
Old 03-14-2009, 09:45 AM
Do the eec IV STORE the code the car get's the missfire eng light come's on then missfire go's away eng light go's away no storead codes i have a actron scanner new plugs , wires , crank sensor ,
Old 03-14-2009, 10:41 AM
shorod's Avatar
SHO No Mo
I don't believe your 92 will the misfire monitors, so you're going to have to do some good old-fashioned troubleshooting. Remember what it takes to properly combust the fuel, compression, appropriate air/fuel mixture, and spark, along with everything in proper time.
You might try doing the the built-in cylinder balance test to see if that reveals a cylinder that isn't pulling its weight.
-Rod
