Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 03-11-2009, 05:10 PM
ald872000 ald872000 is offline
Map sensor
I got a question that is puzzling me
I got a 1990 crown vic LX stock 302 engine
I was at a junk yard and I see a tube connecting from the plenum
To the MAP sensor on almost all 5.0L engines.
Now what I found out in my Crn Vic is that the tube from the Plenum to the Map sensor isn't there. I snooped around with a mirror and flash light to see If I might have a vaccum leak but I found that SOME ONE PLUGGED IT with some kind of rubber stopper.
Now I live in california and I did some research and I get this:
"The Manifold Absolute Pressure (MAP) sensor is used on the 5.0L engine, except on 1990-91 sedans sold in California"
My question is: should I install the rubber tube from the Map sensor to the Plenum or should I leave it as is?
(did a Check Engine light Diagnostic got code 22 {MAP/BP sensor out of self test range.} But I guess it's throwing that code b/c the tube isn't connected. Also I'm getting a funky idle that may be a cause of the tube not connecting to that Sensor
