Old 03-11-2009, 03:54 PM
RezRunner RezRunner is offline
Help with 4.3 vortec
I have a 1995 k1500 pickup with a 4.3 Vortec Z code engine. Does anyone have a fix if the engine runs just fine when it's cold. After the engine warms up it jerks at highway speeds. If I keep the RPM above 2000 RPM it runs fine. The codes I got were the running rich code. So far I've changed the EGR valve and the O2 sensor. Any ideas?
Old 03-11-2009, 06:11 PM
2000CAYukon 2000CAYukon is offline
Re: Help with 4.3 vortec
Engine Coolant Temp sensor may be bad. Have it scanned to see what temp it is reporting.
//2000CAYukon
Old 03-11-2009, 10:04 PM
RahX RahX is offline
You might have a bad fuel pressure regulator. It's the spider dealie in the intake, i'm pretty sure the regulator isn't serviceable separately.
Old 03-11-2009, 10:31 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
If it is CPI, the regulator can be replaced after removing the upper intake plenum and removing the "spider" injector assembly...the regulator is mounted on the firewall side of the base that holds the injectors...about a 2-to-3 hour job. They cost about $45. Install a fuel pressure tester and get readings when the key is on/engine cold, then start it and warm it up and rev it to the problem RPM range and note the pressure. Should be at least 60 psi with key on.
Another idea might be the poppet valves sticking open...they're the ends of the hard plastic tubes on the "spider" that snap into the cylinder heads. Run a good fuel system cleaner liek Seafoam or have the injector spider assy cleaned.
good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 03-12-2009, 11:15 AM
This engine has a throttle body. Does this still apply?
