Old 03-11-2009, 02:30 AM
deadroach deadroach is offline
Exclamation 2001 grand am keyless entry, power locks, dome light, problem
my power locks will not lock when put into gear, dome light will stay on, and horn will not sound when using remote to lock. but when it rains, everything seems to work right. had this problem once before with the security light on. dealership replaced computer and worked great for about a year. could this be a grounding problem.
Old 03-11-2009, 10:45 AM
saturntech's Avatar
saturntech saturntech is offline
Re: 2001 grand am keyless entry, power locks, dome light, problem
Sounds like a body control module issue again, they are known to leak water in that corner, check the connector on the bcm for water intrusion, the pins may be green
Old 03-11-2009, 05:54 PM
J-Ri's Avatar
J-Ri J-Ri is offline
When replacing it this time (if it is indeed bad), fix the water leak. The leaking water will keep ruining every new one you install.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-11-2009, 11:00 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF deadroach !
If you have a sun roof the drains are prone to leak. It runs down the front pillars and runs out onto the fusebox(s) and or on top of the BCM which is under the glove box.
If it hasnt been a full year, fix the drain and the warranty should cover to replace it, if its under the year warranty period.
1999 Grand Am SS 3.4 OHV
Old 03-12-2009, 01:48 PM
Cool Re: 2001 grand am keyless entry, power locks, dome light, problem
thank you for all the advice, gonna try to take a look at it this weekend. that is if the weather is nice.
Old 03-15-2009, 06:22 PM
halofton26 halofton26 is offline
Hey, that sounds like it might be part of my problem!
