Old 03-10-2009, 06:37 PM
pmulls pmulls is offline
removing rear passenger window
some methhead decided he wanted the 6x9s out of my rear deck... depending whether or not i can get the glass how hard would it be to remove the pieces and replace it??? 94 taurus sedan
Old 03-10-2009, 08:45 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: removing rear passenger window
Are you referring to a passenger rear door window, or the little quarter window? The door windows are not too bad to change out. They're actually fairly straight forward once you get the door panel off. And you should be able to find a replacement window for pretty cheap from a salvage yard. There were a ton of these cars on the roads (and now off).
-Rod
Old 03-11-2009, 09:45 AM
the door window. i cant figure out what to use to remove (what i belive) are rivets? holding the window in place???
Old 03-11-2009, 01:00 PM
shorod's Avatar
SHO No Mo
Do you have manual or power windows? If you'd like to send me a private message with an e-mail address for you that can accept PDF attachments, I can send you the steps from the factory service manual for changing the window.
-Rod
Old 03-12-2009, 09:47 AM
its manual i sent you a pm too shorod
