Old 03-10-2009, 11:48 AM
rmrlife021402 rmrlife021402 is offline
cooling issue
i was driving heard a loud pop so i pulled in the gas station and looked and my car was draining coolant the reservoir doest leak but when you run the car and the radiator fills it leaks out fast and i cant find a hole.
Old 03-10-2009, 06:25 PM
rhandwor rhandwor is offline
Re: cooling issue
I would check if the radiator fans are coming on and check both upper and lower radiator hoses are hot maybe a bad thermostat.
Old 03-10-2009, 08:08 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: cooling issue
do you mean you can't find the hole, or you can't find the leak?
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
