Go Back   Automotive Forums Car Chat > AMC/Rambler/ Nash/IH > Rambler
Old 03-10-2009, 06:56 AM
tommyw1992's Avatar
tommyw1992 tommyw1992 is offline
'68 Rogue-too original
I have a '68 Rogue with 290 2bbl. that I'd like to put an electronic dist. and also a GM internaly regulated alt. on. Does anyone know what GM dist. and alt that will work for this?
I also have a '64 Rambler 330 wagon, 6 cyl., 3 on the tree with a pull out overdrive that is all original and runs from Calif. that I'm thinking about selling but there is no title....anyone know what it might be worth?
GIT IN-SIT DOWN-SHUT UP-HANG ON
Old 03-11-2009, 09:12 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: '68 Rogue-too original
Out of curioisity where and when did you get your 68? Oh, and the points and condensors used are GM parts as most of the ignition system was GM's contirbution to AMC.
Old 03-12-2009, 05:31 AM
tommyw1992's Avatar
Question Re: '68 Rogue-too original
Two years ago I traded a '72 Cutlass straight up for this Rambler because I wanted to have something at the local car shows that wasn't the "same old-sameold"
Back to my question......what GM dist. will work on this as I have SBC dist. and it won't fit....I've also tried a dist. from a straight 6 and it was also different.....I know that I can buy a new one from Summit, but I have a very tight budget{as we all have lately} so I'd like to get a used one, just don't know what to use.
Old 03-15-2009, 05:55 PM
big white bufflo big white bufflo is offline
mallory make a conversion for that all GM were the same so any gm conversion will work look on summit racing and it real easy to convert the old late 70to80s alt over i got tire of the old autolite burning regulator just hve to do a littlle cutting on the gm housing to get them to fit cut the wider side down to the thickness of the org and leave the adjustment side alone works great
Tags
too original....
