Old 03-26-2003, 06:20 PM
chevy trux chevy trux is offline
Talking 454 ss gauges
does anyone know if the 88 454 ss gauges will swap out for the 88 1500 gauges. Ive done some mods and my truck does well over 110. I want a speedo thats a little more accurate and has a higher top out unlike the 85 mph that seems to wrap around at about 95mph. I jst want to know where my true top out is, i have run even with a worked talon tsi down the highway but radar alarms started buggin. So i need to know if the 454ss dash will clip into and function in a c 1500. thanks
Old 03-27-2003, 10:10 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
Ummm....the 454 SS wasn't released until 1990.
*Under Construction - New sig to debut*
Old 03-27-2003, 11:37 AM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
i know that's the case in the newer trucks, which have different speedos, but only one sending unit from the trans.
it would make sense that you could plug in the different cluster if it works on the newer ones, it should be the same technology.
i'm not sure on the origin of the 454ss and what year, but know they didn't make nearly the power that motor is capable of...
what are you running for suspension upgrades and wheel/tire combo?
Old 03-29-2003, 08:04 AM
i did some more thinking on this topic, and i know for a fact that the 454ss wasn't around in 88, considering that that's the first year of the 88-98 body style. the 454 was in the the 88-93 front end range (they changed the grille in 94)...
but i think it was more in the 92ish range, definitely not in 88.
Old 03-29-2003, 08:05 AM
just checked again, they were 90-92.
Old 03-29-2003, 06:30 PM
Shortbus Shortbus is offline
Blah blah blah
Send a message via AIM to Shortbus
Should work.
92 to 94 Has a different connector and used a separate DRAC (digital ratio analog controller)(clear plasic box behind the glove box comp.)for the veh. speed calibration so you could not use anything newer than 91.
88-91 used the cluster for veh. speed calibration and all shared the same connector.
Old 07-30-2004, 07:37 PM
odie79 odie79 is offline
454ss years
According to the 454ss.com website they were produced from 90-93. 1990 is the most common year. This is mainly because they produced 13,748. In the other years, these trucks were made in very limited quantities. I know this is not the point of this thread but, I thought this might be an interesting piece of trivia.
Thewebsite which this information is has been gathered from is http://www.454ss.com/Articles_new/YEAR.asp
Installation Connection Problem: 0-Gauge to 8-Gauge, or Alternate? OnThePike Car Audio 10 12-03-2010 12:49 PM
94 thunderbird radiator fan/ temp gauge problem frustrated by now Thunderbird 19 08-09-2009 11:05 AM
Oil pressure gauge roknjock2 Chevrolet Classics 11 07-30-2009 08:33 AM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
'04 Tahoe Range/Fuel gauge problem. usn_622 Tahoe 2 02-21-2009 09:58 PM
