Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-09-2009, 09:07 PM
Paul Buxe's Avatar
Paul Buxe Paul Buxe is offline
Red face Clutch effort reduction fix
When I first got Panoz GTRO 0042, the clutch leg effort was 140lb to just move the pedal and 180lb to push the pedal to the floor. UGH, way too much leg effort. I have Factory Five Cobra that I built and I knew that the pedal effort should not be this high.
Well the Panoz high leg effort was due to two things, 1) the hack job that the school mechanic did converting the clutch from hydraulic to cable and trashed the mechanical leverage and 2) the worn clutch pivot shaft and clutch pedal pivot (all a result of the school hack job). With the clutch fix the pedal effort went down to 40lbs from 140lbs. Now the clutch effort is very easy and the engagement is very smooth.
So I jumped into making the pedal assembly like on my Cobra.
  • First thing to do is cut the clutch pedal just below the old pivot point and fabricate a new platform which you can relocate the clutch quadrant.
  • Drill and tap the quadrant, drill out the pivot and press in a new bronze bushing. Not a good idea to have the aluminum quadrant pivot on a steel shaft. McMaster-Carr
  • Remove the clutch/brake hydraulic assembly and drill new mount holes 0.750” rearward so the new quadrant will clear the firewall.
  • Buy a clutch firewall adjuster from Forte’s parts in MA.
  • Remove the square tube clutch bracket on the engine side of the firewall.
  • Cut a 1” section out of the steering shaft cover to allow for brake pedal movement now that the clutch/brake assembly is moved 0.750” rearward.
  • Weld in a double support plate for the clutch adjuster. Drill a hole for the clutch adjuster.
  • Buy a clutch fork extender bracket from Forte’s parts. Bolt on the extender.
  • Mount the clutch pedal with new pivot rod from McMaster Carr and add in a pedal stop.
  • Bend the gas pedal to match the new position of the brake pedal.
  • Hook it up and you are ready to go.
Let me know if you have any problems. This change also will extend the clutch pedal throw which makes for better feel when working the clutch.
Paul
Paul Buxe
Panoz GTRO-0042 LS2 gone but not forgotten
Miata Chump Car
Mustang GT
Porsche Boxter (wife's ride)
Chev Suburban trailer hauler
Factory 5 Cobra Roadster, 392 stroker
You have to grow older, but you don't have to grow up
Old 03-10-2009, 08:45 PM
eric1h eric1h is offline
Re: Clutch effort reduction fix
pics!!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
Old 03-10-2009, 10:30 PM
feqrags feqrags is offline
is it me? pic's won't open. sounds great just - i'm a needs picture person .. thanks
Old 03-11-2009, 06:36 PM
Paul Buxe's Avatar
Sorry you can't see the pictures I posted. This is my first try at posting pictures, so...............anyway I can see them but...............if you will email me I can send them to you.
Paul
Paul Buxe
Miata Chump Car
Mustang GT
Old 03-13-2009, 03:25 PM
sfbond sfbond is offline
Thanks for the fix! Please send photos to [email protected]
Old 03-13-2009, 03:35 PM
Panoz26's Avatar
Panoz26 Panoz26 is offline
or send us the pics and we can post.....
either way.
[email protected]
Devin - (aka Panoz26)
Formally WC Car # 26, Red
Now = WC-GT2 # 211, Black
Old 03-13-2009, 08:22 PM
Paul Buxe's Avatar
Thats really strange, I can see the pictures on my computer, but I at my daughters house and the pictures don't come up on her computer. I used the "insert image" feature on the thread and it looked like it worked fine, but I guess not. Anybody have an idea why not? Anyway, I am sending the picyures toronbond so he can post them.
Paul Buxe
Miata Chump Car
Mustang GT
Old 03-13-2009, 09:36 PM
Wess-RA's Avatar
Wess-RA Wess-RA is offline
Paul,
We've all had to struggle through this. Go to photobucket.com and open a free account. You can download your pics to that account. Then you cut from your download and paste into your reply thread on this forum. I'm not an expert as to why it works, but I imagine the format is changed to something this forum can interpret.
Uwe W.
Panoz GTS
Porsche 996 Turbo
Old 04-21-2009, 09:01 AM
wirewheel99 wirewheel99 is offline
Cool Re: Clutch effort reduction fix
hydraulic clutch kit includes pedal-master cylinder and resevoir-line and slave cylinder
$100
Old 04-21-2009, 02:31 PM
Cobrafang Cobrafang is offline
$100
Are you selling this?
-Cobra (A.K.A Tom D)
Racer and Gamer
Panoz GTRA (Mystery Chassis #) (Track Toy)
2001 BMW M5 (Road Toy)
2006 F250 (Car Hauler)
2002 Odyssey (Kid Hauler)
Old 04-21-2009, 02:38 PM
Yeah, hes selling them, he said he had a few
Old 04-27-2009, 03:48 PM
AIMidwest27 AIMidwest27 is offline
$100
What is the size of that master cylinder ?
Ted R. Schwartz
NASA American Iron Mustang #27
Old 04-29-2009, 08:45 AM
It is a 1 1/8 Wilwood master cylinder with Wilwood aluminium pedal, stainless steel braided hydraulic hose, heat shield for the hose and a Wilwood slave cylinder...Hope this helps..
Old 05-30-2009, 09:52 AM
Hayes, if you still have this I'll take it, I really just need the pedal will you sell just the pedal?
Otherwise if i HAVE to I'll take the whole setup.
Old 07-02-2009, 03:02 PM
NZGTRA17 NZGTRA17 is offline
$100
Do you still have some of these for sale as I would like to purchase 1?
Thanks, Kel.
Kel M
Panoz GTRA #17
New Zealand
