Old 03-08-2009, 09:57 PM
mega8man's Avatar
mega8man mega8man is offline
Exhaust Questions
If i remove my cat and my muffler from my 98 silverado what should i do about the sensor on the cat? will it cause trouble codes over and over if i take it off? Also i have heard that there are no downsides for removing them but i should change the oil more frequent i was just wondering what the repercussions would be for removing them.
Old 03-08-2009, 11:34 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Exhaust Questions
Removing cat is illegal.
MT
Old 03-08-2009, 11:39 PM
bigbadram51 bigbadram51 is offline
Also in a lot of cases. you lose performance and MPG's. They do make high flow cats if you think your engine will be better with no backpressure.
2004 Silverado Half-Ton Crew
7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block
3" PA Body Lift
Yukon 4.88's with Auburn LSD
Xentec 6500k HID lows, Silverstar Ultra brights
Wade in channel window vents
Covermaster Top
Flowmaster 40 series, dual outs
Nelson 89/91 HOT TUNE
20" MB Gunner 6's, 37" Toyo Open Country MT's
Eclipse AVN6600 w/sirius and IPOD controllers
Code Alarm w/ Remote Start
Old 03-09-2009, 06:32 AM
mega8man's Avatar
For some reason i knew that would be the response thanks anyways.
Old 03-09-2009, 06:53 PM
j cAT j cAT is offline
the removal of the cat's will not increase MPG....the engine controls on this vehicle ,,require all this to be working, or you will use more fuel and be a pollutor...
whoever stated your vehicle would run better is an idiot..
