Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-08-2009, 06:53 PM
bendrewjr bendrewjr is offline
1996 jimmy
Help needed. On my 96 jimmy I here water sloshing. Its seems to be in the cowl (fresh Air system). How do I find the drain for this. Where is it located and and all will be input appreciated Thank you Andrew
Old 03-08-2009, 08:51 PM
cherokee4 cherokee4 is offline
Re: 1996 jimmy
sounds like it may be in door , check and make sure .cowl shouldnt hold water . l
Old 03-08-2009, 09:58 PM
old_master's Avatar
Advisor/Moderator
Re: 1996 jimmy
Check the engine coolant level. Very common for intake manifold gaskets to leak on the 4.3L engine. If that's the case, you're hearing coolant slosh through the heater core.
You have to know how it works,
to figure out why it doesn't.
Old 03-09-2009, 08:38 AM
b1lk1 b1lk1 is offline
Re: 1996 jimmy
Exactly what just happened to my truck.
