Old 03-08-2009, 11:53 AM
kc9dre kc9dre is offline
98 C1500 Possible EVO issue?
Ok I have read about the sensor that installs in the cab. But my issue is different than everyone elses and I think it may be on the PS Pump itself. We had an ice storm here a month ago and my wife got the truck stuck, So I went to rock the truck out of being stuck. In the process of doing this I had some wheel spin and I turned the streering wheel to to change the direction that the truck was moving in. and now I have NO POWER ASSIST at LOW speed. if the Fluid is cold it works once it warms up it gets tough again where you have to be moving to turn the wheels. Is it the pump itself? Is it the Variable Orfice solinoid? And I went to the dealer then they tell me the EVO solinoid has been discontinued... So what now? I we going to just bypass the damn EVO but I dunno. Can I just take the EVO Solinoid out and put a hose fron a 1996 on there and it be happy? Or do I have to replace the pump? Take out the EVO and cap the hole? (Leaveing the EVO attached to harness.) Lookin at the Pump though it looks different, but no one stocks the pump with the EVO Solinoid on it. so If mine is broke where do I get one at? Yes I know salvage yard diving but how long will that part last if I can find one?
Now the symptom I was feeling before was the pump had a slight whine to it, not a loud one but I knew it was there.
I love my truck other than not being able to park it easily... can;t always find a pull through parking space. LOL
david
Old 03-08-2009, 08:43 PM
777stickman 777stickman is offline
Re: 98 C1500 Possible EVO issue?
David: No you can't just take the EVO solenoid out and put a different hose on it as the solenoid does not have a hose on it, only wires.
From your post I would suggest replacing the pump, and if you try harder you should be able to replace it with the EVO system. If not, then just just replace it with a non evo pump and tape the EVO wiring connector back out of harms way.
Good luck...........
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Tags
evo solinoid
