Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Firebird Discussions
Old 03-07-2009, 12:51 PM
porschegonzo porschegonzo is offline
Send a message via Yahoo to porschegonzo
Odd Sound from Right Headlight Assembly
I tried to post this question and video with my last post but yahoo was taking to long to process the second video. any idea what this is. its coming from the right headlight only and only when it is lowered
http://www.youtube.com/watch?v=BjNIIJmW-po
Old 03-25-2009, 01:47 PM
91 bird 91 bird is offline
Smile Re: Odd Sound from Right Headlight Assembly
the left one looks like worn bushings at the motor or lower link. the right one w/the noise sounds like the gear inside is striped. i have been told you can take the gear out and rotate it 180 deg. and the problem will be fixed. i tried that only to find out my gear had shattered. could try a salvage yard for parts as those parts are costly. i like the videos, they are better at diagnostics. one persons tap is another persons knock.
Old 03-05-2010, 11:36 PM
rsteele34 rsteele34 is offline
mine did the same thing
it will go out in the up position eventualy
u need to change the motor
about $74 with exchange at autozone
u will cuss abit while u work on it
Old 03-13-2010, 04:29 PM
importeater38's Avatar
importeater38 importeater38 is offline
Send a message via Yahoo to importeater38
if you plan on keeping the car for any significant length of time i would buy replacement aluminum gears instead of replacing the whole motor. http://rodneydickman.com/n113.html this link takes you to a guy who sells a nice kit with detailed instructions. Fix it once with these parts and you will never have to touch it again. I actually bought a few of these kits in anticipation of my headlights failing. Havent had to install yet though.
93 trans am hurst shifter and zo6 rims. 94 trans am GT. functional ram air hood w/k&n air box, ROH rims, toyo skins, Borla cat back SS, TB bypass, de-screened MAF, BBK underdrive pully, Mieziere electric water pump, spec stage III clutch. '06 Yukon Denali XL, black, loaded. http://www.cardomain.com/ride/711131
Old 03-22-2010, 10:56 PM
Ralph123's Avatar
Ralph123 Ralph123 is offline
Here's the fix for this problem. I did this a few years back and the problem hasn't come back and it didn't cost me anything except my time.
http://www.bfranker.badz28.com/headl....htm#FreeGuide
