Go Back   Automotive Forums Car Chat > Dodge > Shadow
Old 03-06-2009, 08:25 PM
GrndNatnl GrndNatnl is offline
Question Help with rear speakrs in 92 Shadow
Hi folks,
I need to replace the rear speakers in a '92 Shadow ES.. They're supposed to be 5"x7" however none of the current aftermarket 5x7's seem to fit. The mounting holes do not line up with the studs on the factory brackets. The set of Pioneer's that I picked up tonight were totally off. Part of the speaker frame hit the bracket, and the two studs on one side were basically in the cone region. Not even close to lining up.
Are some sort of adapter plates required for these? Are there any direct fit speakers available? What the heck?
Any help is much appreciated. I'm stuck riding around with no rear speakers until I find some that fit. Thanks.
'87 Buick Grand National, 11.35 @ 116.7
'88 Chevy S-10 pickup, 2.8L V6 auto
'92 Dodge Shadow ES, 3.0L V6 5-spd
Old 06-28-2009, 04:12 AM
family_dad family_dad is offline
Re: Help with rear speakrs in 92 Shadow
i did both because i didn't know if you had the hatch or drop top
1992 Dodge Shadow Hatchback
without Infinity system
Aftermarket Stereo Installed [change]
Factory replacement info:
In-dash stereo
6-15/16" depth; Size code CG,E,GC,IR,UR
Front speakers
Front Door: 5-1/4"
Rear speakers
Side Panel: 5x7"
Far rear speakers
Rear Seat Side Panels: 6-1/2" factory speaker note
your factory speaker doesn't match any aftermarket speaker size exactly
1992 Dodge Shadow Convertible
with Infinity system
In-dash stereo
6-15/16" depth; Size code CG,E,GC,IR,UR ; Non-standard dash opening (special integration package required)
Front speakers
Front Door: 5-1/4"
Far rear speakers
Rear Seat Side Panels: 5x7"
Old 07-13-2009, 09:31 AM
John81 John81 is offline
Try to repair yours.
Hoosier
