Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 03-06-2009, 07:25 PM
Rajan Rajan is offline
Unhappy 99, sl1, muffler leaking
I've noticed that there is some liquid leakage from muffler. The leakage is
so much that it's covered about 24 sq. ft of area. Liquid is blackish in colour
and leaks only when the car is running and in drive. All the fluid levels are OK.
Is this dangerous ?
Please help me to find out the poblem.
Thanks in advance.
Old 03-06-2009, 09:39 PM
saturntech's Avatar
saturntech saturntech is offline
Re: 99, sl1, muffler leaking
How is the car running?? is there any smoke coming out of the exhaust?? does the liquid smell like gas?? Do you notice if the liquid evaporate after it hits the ground?
Old 03-06-2009, 10:41 PM
Cat Fuzz Cat Fuzz is offline
Probably just plain water normally produced by the combustion process.
Old 03-07-2009, 07:42 AM
Thanks for your response. The car is still running fine. The smoke coming out of
the exhaust is normal and the liquid doesn't smell like gas. Liquid is evaporating
and leaving marks on the floor. Liquid is blackish mixed with water and doesn't
have any smell.
Thanks once again.
Old 03-08-2009, 04:37 AM
RC1488 RC1488 is offline
have any smell.
Thanks once again.
Its just water thats mixed with the carbon in the pipe. Normal
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 03-08-2009, 04:22 PM
Thanks. I found out 2 small pin sized holes in the muffler.I've applied
muffler cement over them and now it seems to be OK.
Thanks once again.
Old 03-08-2009, 04:28 PM
I'm pretty certain those little holes are supposed to be there to allow drainage. I've seen them in new mufflers.
Old 03-08-2009, 07:29 PM
saturntech's Avatar
Yes, those holes are there just for that reason, its means that your engine is running good it you have water coming out, I just thought that it was a little excessive the way that you were explaining it
Old 03-09-2009, 08:44 PM
I have been driving this car for 4 years and never faced this problem. I also
used muffler cement over the holes but that is not working. The water is
still leaking. Any suggestion(s) ?
Thanks.
Old 03-09-2009, 09:21 PM
Let it run out! It's supposed to do that. If you prevent the water from escaping you might cause some other problems.
Old 03-10-2009, 06:57 AM
saturntech's Avatar
yeah, especially if it builds up in the exhaust system and your in a area where it could freeze
Old 03-13-2009, 09:39 AM
drew300 drew300 is offline
the water comes from burning the hydrogen in the fuel. Let the water out. My car has those holes there too, they're factory. Remember how quickly the old mufflers rotted out? I used to drill holes in them so they'd drain.
