Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 03-06-2009, 04:28 PM
BUBBANLOISN2 BUBBANLOISN2 is offline
Cool 99 tahoe power window problem
I bought a 99 tahoe 2wd 4 door all the windows work but the driver window only goes down 3 inches then makes a stuttering noise and if its does not do that it does not work at all i checked all fuses and the motor is working not sure what else?
Old 03-06-2009, 09:30 PM
roadrunner2 roadrunner2 is offline
Re: 99 tahoe power window problem
If you checked the window motor you must have had the door panel off.
Why didn't you check to make sure the window slides without binding?
Does the window only go down and not up? If so, the regulator may be faulty.
The problem with doing nothing is not knowing when you're finished.
Old 03-20-2009, 09:12 PM
j cAT j cAT is offline
the window regulators here in the cold new england weather fail at a very rapid rate...rusted cables to motors shorted out from water entry.....
I replaced all of mine...
