Old 03-05-2009, 11:22 PM
3000gt87 3000gt87 is offline
Eh... Six Cylinder Misfire?
Hey, I've been having some problems with my gt, 91 SL Auto DOHC, It's been misfiring, stalling at slow speeds and stops, and sending crazy signals to the tack, I pulled the codes (twice, cleared them to see what came back) and got: Ignition Coil, power transistor unit, 1-4, Igintion Coil, power transistor unit, 3-5, and Igintion Coil, power transistor unit, 3-6.
Should I throw a new PTS, coils, or Cam sensor at it first?
(Or what else could this mean?)
Thanks for any and all help!
Oh, and for a while, this was all happning when I got at, or around a quarter of a tank. O.o
Old 03-05-2009, 11:25 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Eh... Six Cylinder Misfire?
Check the caps in the ECU first
Old 03-05-2009, 11:26 PM
Hmm.. I was wondering that too... Eh, it's never just a eazy fix with this thing... maybe I can pull that out tomorrow and see if it's leaking..
Oh, and for a while the symptoms were all happening at or around a quarter of a tank... O,o
Old 03-08-2009, 10:39 AM
3S Motorsports 3S Motorsports is offline
If you know anyone with a 3000gt/stealth (any year, dohc) I would try swapping out the PTU to test. It could be the ecu, but I have never seen it throw codes for all the coils before. Typically it is 1/4, or 3/6. But the ECU can definately throw a curve ball every now and then.
-Steve
-Steve
-1995 VR4-3.5L Stroker Mod
World Record for 15G's @ 504awhp- Much more power soon to come!!!
-2005 Evo 8
-2008 Jetta 2.0t
-2005 Yamaha R1
-Ultralight Mosquito XEL (coming soon!)
Old 03-08-2009, 11:59 AM
Stealthee's Avatar
Felt so special you had to sign your name twice?
On my TSI when the ECU went bad it threw about 8 random codes.
Old 03-19-2009, 12:21 AM
Well, I plugged in a PTU while my car was having one of it's fits, and it still happened with the good one, so it's not the PTU.. WAIT, does it need a little bit of time so the ecu can get used to the new one?... seems almost like heat makes it worse. I played with all the harnesses, and nothing changed.
Any other ideas other then the ecu?
What about a crank or cam sensor going out?
Got some newish coils to change out and try, to see it anything changes...
Old 03-19-2009, 12:27 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Unplug the battery for a few min and the ECU will reset. That way you can rule that out.
Old 03-19-2009, 12:33 AM
Ok, Yeah, we were in a hurry today and I didn't even think of that.. Lol Hopefully, it will act up as much tomorrow as it was today. (Never thought I'd say that.. lol)
Thanks.
