Old 03-05-2009, 07:57 PM
StoneHarley's Avatar
StoneHarley StoneHarley is offline
Looking for a new window switch.
I am trying to replace my driver's side window switch assembly and was wondering where I could look. I already know to look in junk yards, but I'm trying to find one new if possible.
I try not to think too much because it usually gets me in trouble.
Old 03-05-2009, 08:29 PM
bsansa bsansa is offline
Re: Looking for a new window switch.
EBAY:
http://cgi.ebay.com/ebaymotors/LF-Ma...Q5fAccessories
or
GM Parts Direct: http://www.gmpartsdirect.com/
GM Part #10440281
Old 03-05-2009, 08:40 PM
Thank you for your help. I'll look into it.
Old 03-05-2009, 09:21 PM
harmankardon35 harmankardon35 is offline
my bet is your driver side window is not going down...pretty common fault in the drivers multi-switch with the auto down feature. I took mine apart and got some electronic cleaner in there and lightly scraped the contact surfaces with a small pin or something like that to clean any film or oxidation to create a good contact... They are not too easy or too hard to get apart, a bit of studying required to get down to the metal contacts in the faulty switch....but it was well worth it as my window switch now works fine again. Price in canada for a switch is $130 new
Old 03-06-2009, 02:03 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Could very well be the window regulator is locked up. That would be the most common window related problem. Im sure you already have, but you wanna be sure the switch is bad. Just because you cant hear the motor doesnt necessarily mean anything, you wanna get in there and check it out with a test light. It does require taking the door panel off, but you have to do that anyway to replace anything besides the switch. Just food for thought.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
