Old 03-05-2009, 03:35 PM
nash.winfore nash.winfore is offline
Unhappy Front right turn signal light not working ('02 intrigue)
I tried replacing the bulb, and the fuse, but still no luck.
Anyone have any idea what else I can check? I'm going on a roadtrip soon and I would be so thankful if someone could help me!
Old 03-05-2009, 08:26 PM
dtownfb dtownfb is offline
Re: Front right turn signal light not working ('02 intrigue)
The socket that holds the bulb is probably bad. Remove the bulb and inspect the contacts. If there are "burn" or black marks on the contacts, you need to replace the entire socket. It's a very common repair on the Intrigue. Using the turn signals as the daytime running lights was not a good idea.
Old 03-06-2009, 02:05 AM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
You can also check the wiring before the socket with a test light to make sure that power is even getting there like it should.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
Old 03-06-2009, 03:45 AM
whoo! thank you!! it was totally the socket : ) I've been meaning to get this fixed for ages but it was never a good time to take it into the shop, and now I don't have to! Thank you very much : )
Old 03-06-2009, 09:39 AM
You can buy the socket at a Gm dealership or from www.rockauto.com or www.gmpartsdirect.com. The websites tend to be cheaper but you have to pay for shipping. It may be a wash.
It should take you about 5-6 minutes from opening the hood to washing your hands.
Old 03-06-2009, 04:23 PM
harmankardon35 harmankardon35 is offline
I usually take a small file and clean the contacts, get GM bulbs with the glass socket as opposed to the cheap plastic ones and slightly bend the contacts outwards to create more pressure in the socket and add some dielectric grease. Your socket will not burn out again. Replacing the socket will fix the problem temporary until it just burns again. Another option is to pull the DRL fuse and stop those damn lights from burning on high all the time. Its a terrible design, no signal bulb is designed to be left on high for extended periods, only to flash high
Old 03-08-2009, 07:01 AM
Jimmy Olsen Jimmy Olsen is offline
Pulling the fuse is the way to go. It means that you lose the automatic headlight feature but to me that is no big deal. If I want DRL I turn on the headlights.
1995 Dodge Ram 1500, 143k miles
1999 Oldsmobile Intrigue, 121k miles
2006 Subaru Forester, 68k miles
Old 03-08-2009, 05:09 PM
dizzle1's Avatar
dizzle1 dizzle1 is offline
So the accessory will be the daytime running lights then but the dash would light up I think.
Which fuse kills the day time running lights, is it under the hood?
For me recently the front left turn signal didn't work I took it out a saw that the bulb was a little melted and I lifted up the contact and put a tiny piece of aluminun under it and now it works good.
Old 03-09-2009, 05:45 AM
The fuse is in the fuse panel by the passenger door. I suspect that your fix will be a short-term one.
