Go Back   Automotive Forums Car Chat > Saturn > Vue
Old 03-05-2009, 02:09 PM
jjchevy jjchevy is offline
2007 VUE rear door latches sticking
I have a 2007 VUE and periodically (usually when it is real cold outside) the llatches on the rear doors stick and the door will not stay shut. I spray em with wd40 and work the latch untill it catches properly again then it is fine for a few weeks then sticks again. Anyone else have this probem? It happens on both rear doors
Old 03-05-2009, 02:19 PM
saturntech's Avatar
saturntech saturntech is offline
Re: 2007 VUE rear door latches sticking
Check the doors alignment, make sure that the door strikers are in the right position, make sure all the gaps on the outside of the doors are all equal
Old 03-06-2009, 03:16 PM
I checked the alignment and it seems OK When I push the latch in with my finger it should catch and stay in until I pull up on the handle but it doesnt stay until I lube it and work the lube in
Old 03-06-2009, 09:42 PM
saturntech's Avatar
sounds like the latches need to be replaced, do you have warranty left?
Old 03-10-2009, 09:57 AM
of course it is out of warranty
Old 03-25-2009, 04:38 AM
coolworld coolworld is offline
check the door alignment.if it is not proper aligned then go to workshop and ask them to repair it otherwise it will create big problem.
Old 08-22-2009, 09:39 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
I don't know if it applies to the 07's as well, but I just got a recall letter in the mail for my 08. the recall is for the doors (aparantly only the ones with body color handles)not staying latched. acording to the letter, the fix it to replace the handles with chrome door handles.
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 09-04-2009, 08:15 AM
saturntech's Avatar
No, its just for the 08
