Go Back   Automotive Forums Car Chat > Pontiac > Sunfire > General Discussions
Old 03-04-2009, 10:34 PM
badbrad76 badbrad76 is offline
98 sunfire 2.2 no compression on all 4 cyl.
Bought a 98 sunfire with the 2.2 ohv engine, 5 peed manual transmission last week. Owner said it had been running great then just overheated, but not real bad. After i got it back to the shop i removed the head to find the aluminum cap off a spark plug squashed into the head.
Pulled it out and cleaned up what little damage there was then proceeded to replace head gasket (as it was blown) and reassemble engine. Head was tightened to spec and in sequence.
Tried to start and no compression??
Thought maybe the timing chain had jumped because of the crud in cylinder...nope...timing was bang on. Gears were good and so was tensioner and chain.
Finally found the valves were leaking...all 8 of them!! I backed the rockers off and re-adjusted them finger tight as you would if you were adjusting valve lash on a solid lifter (slight clearance) and now have compression on all 4, but obviously i cant run it this way.
Does anyone have any idea what would cause this?
All the rockers are working so i dont believe that the lifters are the problem..checked the pushrod lengths, they ARE the factory rods. No bent valves, they were all checked when head was off.
Im stumped...the only explanation i can come up with is that some dumbass had the head decked/milled and didn't do the valves, in which case it never should have run.(might have been a sales pitch)
Is there any way of telling if the head was shaved down?? What else could it be?
Sorry for the long post, just want to get all the info across clearly.
Old 03-05-2009, 05:48 AM
Re: 98 sunfire 2.2 no compression on all 4 cyl.
Anybody?? I gotta get this figured out as the wife is teasing the hell outta me. lol
Old 03-05-2009, 06:30 AM
Does anyone have a good overhead view of the rocker arms for this engine?? Maybe they were replaced with the wrong ones??
Old 12-22-2009, 02:41 PM
twistedtaurus twistedtaurus is offline
Angry Re: 98 sunfire 2.2 no compression on all 4 cyl.
Hey did you ever figure it out? I am having the same problem. Bought the car from a kid who said it overheated then became hard to start, had low comp readings on 2 and 3 so he had head surfaced and replaced gasket. After installing head he could not get any compression so I bought it for a steal thinking he just didnt tighten head correct and to my supprise after going thru the motions I now have the same problem. Thanks for any info
Old 12-23-2009, 04:40 PM
Oops sorry had a brain fart all I had to do was add a head gasket shim because after milling the valves were hanging open. anyway that fixed it
