Old 03-04-2009, 08:46 PM
fatsog123 fatsog123 is offline
Is I possible to change ABS Booster without having too bleed brakes
I have a consistent hissing coming from my brake booster.The brake pedal is firm with the car off,but when on, goes down to the floor easily.I wanted to know was it possible to take off master cylinder,change booster and put back,without bleeding brakes.I have to go to the damn gmc dealer for these damn ABS brakes. I hate shops.
Old 03-04-2009, 09:09 PM
old_master's Avatar
Advisor/Moderator
Re: Is I possible to change ABS Booster without having too bleed brakes
If you unbolt the master from the booster, and don't open any brake lines, you don't need to bleed the brakes.
You have to know how it works,
to figure out why it doesn't.
Old 03-04-2009, 10:50 PM
will the brake line brake if pulled the master cylinder back a little?
Old 03-05-2009, 01:20 PM
old_master's Avatar
Advisor/Moderator
There should be enough flex in the lines to allow movement to replace the booster. Just be careful not to kink the hydraulic lines and you should be fine.
