Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-03-2009, 08:17 PM
bluefever bluefever is offline
01 camry,no high beams!
my '01 camry le has lost it's high beam completely,the low beam and daytime running lights work perfectly fine,when i flick the switch the light on the instrument cluster comes on,but the lights don't change at all,the bulbs are brand new and all my fuses are good,has anyone else had a similar problem?
2013 Ford C-Max Energi, 2005 Ford Five Hundred Limited AWD, 1991 Dodge Monaco LE
Old 03-03-2009, 09:55 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 01 camry,no high beams!
Are you positive you replaced the bulbs with the correct part number? That is the logical cause.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 03-04-2009, 09:33 AM
yes i'm sure.
Old 03-04-2009, 11:45 AM
somick's Avatar
somick somick is offline
There could be a relay issue. Have you tried www.camrystuff.com? There suppose to be a manual for electrical troubleshooting there.
Good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 03-05-2009, 04:01 PM
DFBonnett DFBonnett is offline
As somick noted, DL the manual on the referenced site and check the section for body electrical.
