Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 03-03-2009, 03:50 PM
carhauler carhauler is offline
GTS Rotors
It's time to replace the Brembo rotors on our GTS 40 car. I'm having a difficult time matching up the rotors with the Brembo catalog, did they change part numbers?
Suggestions as to where to find rotors, I show part # 09.7639.
Thanks
Carhauler
GTS #40
Old 03-03-2009, 05:03 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Re: GTS Rotors
Are you sure the rotors aren't PFC?
Have Fun
Jim Pomroy
96 Miata track car.
2012 Camaro SS.
Backdraft Racing Cobra #930
92 Miata "LemonDrop"
Saturn V Rocket Miata Crapcan #81
99 Miata daily driver.
Old 03-03-2009, 07:12 PM
panozracing's Avatar
panozracing panozracing is offline
Re: GTS Rotors
The GTS uses Brembo and yes they changed the front rotors to a new model and style. Call Panoz, best price in town and keeping them in business to continue to support us!
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 03-04-2009, 12:51 AM
boothkc boothkc is offline
Re: GTS Rotors
Only the GTRA cars use the PFS rotors.
Panoz updated the GTS rotors last year to a more common "Nascar" style (at least that's what they told me) and you have to replace the hats etc. I think the old hubs work, but ask them. You can order them from Panoz.
Kevin
GTS & GTRA
Old 03-04-2009, 08:22 AM
Re: GTS Rotors
Phone number? Thanks
Carhauler
GTS #40
Old 03-04-2009, 08:34 AM
Panoz Paul Panoz Paul is offline
Re: GTS Rotors
Good Morning ... Call Josh @ Panoz , he leads their parts dept.
Great people W/ lots of support !!! 770.867.4796 ... He can also talk to John Leverette / Cheif Engineer about your spacifics ...
Hope this Helps / Paul W.
Old 03-04-2009, 09:02 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Re: GTS Rotors
Brandon can help as well. Is this rotor style / model change more cost effective?
Jim McGovern
~ Building 289 Lemans Replica
~ '92 Mustang Coupe: 347ci / Carb
Pictures
Old 03-05-2009, 07:08 AM
Re: GTS Rotors
I was told the previous brembo rotor/hat pkg. was discontinued by brembo.
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
Old 03-05-2009, 08:37 AM
Re: GTS Rotors
I have a call into Panoz and will report back my findings. Another question, has anyone gone to a wider rim and needed to change our their wheel lugs? I've gone to a 9.5 BBS rim with Michelin Slicks and found that the 3" wheel lugs are too short when used with a wheel spacer. Any sources for 1/2" by 4" lugs with a .563 knurl?
Carhauler
GTS #40
Old 03-05-2009, 09:55 AM
Re: GTS Rotors
Josh from Panoz just quoted the following prices for new hats and rotors to fit the GTS cars.
Rotors $358/each, Hats/each $231, plus about $100. in fasteners, washers and nuts.
Not cheap.
Carhauler
GTS #40
Old 03-05-2009, 12:32 PM
jmimac351's Avatar
Re: GTS Rotors
HA! That's funny, I thought you just said it would cost $700 to replace a rotor. Good one.
Jim McGovern
Pictures
Old 03-05-2009, 02:17 PM
Re: GTS Rotors
That's right, roughly $700 each side
Carhauler
GTS #40
Old 03-05-2009, 03:17 PM
GTS#25's Avatar
GTS#25 GTS#25 is offline
Re: GTS Rotors
Carhauler,
If you are running 18" wheels, you do not need to use the spacers. Only needed on the 17" fron wheels.
Doug
Old 03-05-2009, 03:24 PM
Re: GTS Rotors
Originally Posted by GTS#25 View Post
Carhauler,
Doug
Because of the wheel offset, 18's being more offset?
Carhauler
GTS #40
Old 03-05-2009, 06:25 PM
Re: GTS Rotors
It all depends on the wheels. The reason the spacer was used was to enable the same rim 17's and 18's (this is back when they ran the same tire all the way around) to be able to mount front or rear. When I made my 18's (we went to 18's before Panoz did and we worked with Joel Grewett but he was still fighting things out with SCCA so he didnt have a true spec yet), that I got from CCW, I continued to use the spacers. We originally went with 18x10's and 18x12's and we kept the spacer because Joel was telling us we might have to use 18x10's all the way around. So our rims needed the spacer to work on any corner. We since bailed on that but still use the spacer. Wider track cant hurt (i dont think so anyway).
Brian G.
2000 Panoz GTS #420
NASA ST1
427ci Stroker
