Old 03-03-2009, 11:35 AM
72mino 72mino is offline
2000 Grand Prix backfire. Oops
I tried to get my cousin's GP started to get it to my house to diagnose a noise (brakes or wheel bearings). Battery wouldn't take a charge, would turn over a bit slow with the charger/jump stater hooked up. I decided to try some starting fluid... Any idea what starting fluid + backfire + plastic UIM equals
Old 03-03-2009, 11:39 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 Grand Prix backfire. Oops
Some backfire is normal in this condition. The backfire is of concern when the UIM plenum blows up goes into pieces.
To start you should get the battery checked out.
Timeslip 08/12/06
AF Community Guidelines
Old 03-03-2009, 12:32 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The UIM explosion risk is why I never use starting fluid in an air-only intake. For testing purposes, I use WD-40 or some other flammable spray lubricant which is less volatile than starting fluid but flammable enough to fire the engine.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 03-03-2009, 03:07 PM
CrazyHorst CrazyHorst is offline
Good idea to check the B+ connection to the battery - check the face of the ring-terminal and also take off the red protective rubber boot to make sure the crimp to the wire still has good integrity.
Be careful with the bolt torque as the threads go into a lead (Pb) pocket.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 03-03-2009, 05:14 PM
Sounds like I'm not the first person to ever blow up an UIM, I just wish I had heard of it before I tried starting fluid.
BNaylor - I appreciate the advise, but I already knew the proper way to get it running, I just tried a shortcut to get it to my house where I have tools. The shortcut backfired on me (pun intended).
richtazz - I didn't even think about trying WD40, but I will from now on.
CrazyHorst - I'll check out the connections, but I think the battery is just shot. It doesn't seem to be holding any charge at all, but I also haven't check the water level in the battery.
Thanks for all your replies. I have the parts on the way, and I'll check the water level in the battery, connections, and throw a trickle charger on it for a couple of days to see what happens.
Dustin
Old 03-04-2009, 09:55 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Did you blow up the intake, or did it just backfire?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
