Old 03-02-2009, 10:03 PM
rsking26 rsking26 is offline
Massive Coolant Loss
I've got a 94 K2500 5.7 w/a 140K. About two weeks ago noticed the temp was rising over where it usually rested. Once it got up to about 3/4 the way to the red, pulled over let it cool and nursed it back home. It did this once again but barely got over 240 before it dropped back down to around 190. Searched around on AF and realized I probably had some air in the cooling system. Let the engine get up to temp and then let it cool, topped off coolant in radiator and reservoir and it seemed to do the trick. Everything ran great for the past week. However, tonight when I got home after driving back from town (about 5 miles) the temp went back up to just over 240. When I parked steam was pouring out of the hood and coolant seemed to be literally pouring out of the back of the engine. Looked all over in the dark and the leak definitely seems to be coming out of the back. Most of the coolant coming down near the passenger side of the touque converter shroud. Checked the oil and everything seems to be good. No froth, bubbles or burnt coolant smell on dipstick.
Any idea where the leak might be?
Is there anyway I can get it back drivable to get it to the mechanics?
Appreciate any help.
Old 03-02-2009, 11:45 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Massive Coolant Loss
leaking or partially broken heater hose quick connect fitting. It threads into the intake manifold on the passenger side. When the leak coolant runs along the intake and leaks down the backside of the motor. Worth a quick check.
Old 03-03-2009, 07:22 PM
m74cran m74cran is offline
perhaps a frost plug
Old 03-04-2009, 08:08 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I put out a warning a few months back on those heater hose quick disconnect fittings:
http://www.automotiveforums.com/vbul...d.php?t=935501
In short they're cheap zinc pieces that corrode away from the inside out. If yours has broken off, have fun fishing out the pieces that have fallen in. I found pieces in the water pump and the heater core (I cut the old one open when I replaced it along with the radiator for other reasons) and did a thorough flush. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
