Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 03-02-2009, 08:15 PM
joopa joopa is offline
Reverse indicator on with headlights ('97 Camry)
Hey,
'97 Camry I4. Just started the car this morning and noticed the Reverse Gear indicator in the dash board stays on when I turn the headlights on. (Off when headlight are off)
Car drives fine, tried to wiggle with shift lever to no help.
Could it be the neutral switch? But then why would it only go on with headlights?
Any suggestions highly appreciated.
Old 03-16-2009, 06:44 PM
dpj52190 dpj52190 is offline
Send a message via MSN to dpj52190 Send a message via Yahoo to dpj52190
Re: Reverse indicator on with headlights ('97 Camry)
humm....same here but little different..
When i press the brakes..the reverse light indicitor lights up in the speedometer gauge. That's weird.
Check your lights, if they are working or not.
Old 03-18-2009, 02:00 PM
somick's Avatar
somick somick is offline
Go to an automotive store and ask them to check your charging system. They do it for free.
Check your battery cables for loose or corroded clamps.
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
