Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 03-02-2009, 01:44 PM
andysjimmy andysjimmy is offline
compatible sending units
Hello car nation,i have a 96 jimmy with a 4.3,vortec x block,i also have a 94 sonoma 4x4.I blew the motor in the sonoma and picked up the jimmy,but what i need to know is if the fuel sending unit from the sonoma will drop into the jimmy.Technically both vehicles are the same besides the for a few panels,any input would be greatly appreciated
Old 03-07-2009, 09:28 PM
old_master's Avatar
Advisor/Moderator
Re: compatible sending units
The 94 is OBDI and the 96 is OBDII. Sensors, ECM/PCM/VCM, and wire harness are all different from 94 to 96. It can be done, but it involves a lot of part swapping.
You have to know how it works,
to figure out why it doesn't.
Old 03-07-2009, 10:17 PM
duke350 duke350 is offline
NAPA shows the 96 Jimmy 4 door as part number DFP FG0030, the 96 Jimmy 2 door as part number DFP FG0029, and the 94 Sonoma as part number DFP HP10007 with 2.2l and DFP HP10007 for the 4.3w and DFP HP10007 for the 4.3z. I am not sure, but going off these numbers it would not appear to be a direct drop in and go. Though, you could always pull them both out and compare.
