Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-02-2009, 11:34 AM
ABigWeaney ABigWeaney is offline
starting problem
I have a 92 tsi, and when i turn my car off for about an hour or longer it is hard to start, like it is not getting enough fuel. If i turn the fuel pump on with the fuel pump check terminal and let it run then try to start it will start with no problems, but when i let it sit overnight it is really hard to get it to start. Any one know what could be wrong?
Old 03-03-2009, 12:18 AM
RahX RahX is offline
Re: starting problem
Check fuel pressure, sounds like the fuel pump isn't holding pressure.
Old 03-03-2009, 08:10 AM
How do you check the fuel pressure?
Old 03-03-2009, 09:47 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I dont know about the 4g63 fuel rails but mine has a port on the side that I can screw a fuel pressure gauge in to.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-03-2009, 11:36 AM
My fuel rail does not have a port for a pressure gauge. I tryed changing the fpr but nothing changed. Now it just starts and revs up to about 2k then back to 0. It seems to me that it is not getting enough fuel.
Old 03-03-2009, 11:55 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
So there's nothing for sure saying that you're not getting fuel? Unplug your ISC and see if that changes anything.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-03-2009, 01:15 PM
i suppose that there is not anything saying it is not getting enough fuel. I unpluged the isc and nothing happend. I messed around with it some more and i got it to start but then it only goes to about 1000 rpm then to about 500 and runs like crap and dies.
Old 03-05-2009, 11:37 AM
ok i checked the timing again and this is what i came up with http://i254.photobucket.com/albums/h...ey/carshow.jpg
The bottom pulley is on tdc with the cover. Should i remove the cover and see if the gears are in time? or is it out by 1 tooth?
Old 03-05-2009, 12:01 PM
david-b's Avatar
Dave is THAT guy
Looks off to me. Should be flat level at TDC.
75 Monte Carlo
