Old 03-02-2009, 08:55 AM
Krule Krule is offline
Alternator + bearing + front bumper replacement help please
Hello everyone im back again with some more problems hah
Car: Grand prix Gt 1999 3.8L 435K :O New engine.
So my alternater is sounding like a fire alarm sometimes *usually when it's really cold* wondering if i should have someone rebuild it or just replace it, ill have to find out on prices i suppose.
My passenger side bearing *i think* is going as when i turn into steady right hand curves i get a wounding sound, and sharp right hand turns i right a crunching sound *sounds really awful*. Any suggestions on replacement or if it's something else thats gone?
Recent minor car crash and need a new front bumper, anyone have a site who can sell a front bumper for cheap?
Thanks guys,
-Kyle
Old 03-02-2009, 10:01 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Alternator + bearing + front bumper replacement help please
Since you are up in Canada really not much advice we can give you as to parts cost and availability. IMO you are better off getting a new OE or aftermarket alternator instead of doing a rebuild.
As to your wheel bearing front hubs issue. Listening to noise depending on how the steering is turned is deceptive. You are better replacing the front hubs in pairs.
Especially considering your mileage which is 270296 miles converted.
Timeslip 08/12/06
AF Community Guidelines
Old 03-02-2009, 10:15 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
If your turning right and the noise gets louder than it would be more likely to be the left (DRIVER) side wheel bearing. There are plenty of exceptions to this rule but the above would be the norm. You can also jack up the front of the car and spin the tires while holding onto the strut spring. You will feel a vibration for the one that is bad. Another thing to try is hold the tire at the 12 and 6 position and try to push pull on it. If it has play it is in the wheel bearing.
Old 03-02-2009, 11:51 AM
Hmmm i mean i can understand that and ill give it a try, but it really sounds like it's coming from the passenger side, i've already done an outer tie rod and bushing on the driver side.
Alternator seems to be quite expensive price for a new one or even aftermarket from what i see around here.. maybe ill check some scrap yards.
Old 03-02-2009, 11:58 AM
BNaylor's Avatar
I went through the same issue with my GTP a few years ago and wound up replacing both hubs after some frustrating troubleshooting. The noise test via steering did not work in my case.
You have very high mileage so that is a factor to consider.
Timeslip 08/12/06
Old 03-02-2009, 12:42 PM
Yeah i think ill just change them both out, looking up napa car quest all these places + scrap yards to find out prices.
Do you happen to have a hub removal guide?
Old 03-02-2009, 12:51 PM
BNaylor's Avatar
Yes sir! Glad you asked. Visit our Tips & Maintenance forum and take your choice. A few good write ups on hub replacement. Good luck and keep us posted on the outcome.
Timeslip 08/12/06
Old 03-02-2009, 05:10 PM
CrazyHorst CrazyHorst is offline
IMHO, having the alternator rebuilt is generally more cost effective, I've found.
The downside is that the vehicle is "down for the count" for potentially a few days while the alternator is off at the rebuilder's shop. If you buy one with a "core charge" generally you are paying a slight premium for the convenience of getting it NOW.
Same thing generally applies to starter motors too.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 03-03-2009, 01:44 AM
wlkjr's Avatar
wlkjr wlkjr is offline
I had mine rebuilt for about half the cost of a new one and it was ready the next day. If it's getting noisy, it won't last much longer.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 03-03-2009, 08:49 AM
BNaylor's Avatar
What did it cost you Wally? I can get a refurbed Delco CS-130D alternator for around $100 with exchange from a local shop. No down time waiting. These are the OE Delco alternators redone which includes installing the proper rebuild kit in its entirety consisting of pre-loaded brush assembly, heavy duty voltage regulator, heavy duty rectifier, front & rear bearings and the battery terminal. The problem with a lot of shops that specialize in electrical component rebuilds is they may skimp on what parts are replaced so you never know what you are going to get as a direct result. Replace, if necessary in many cases so reliability may be a factor. Also, if you like doing this type work and have the time to waste you can get a CS-130D rebuild kit with the above components for around $50-$60 and do it yourself.
Timeslip 08/12/06
Old 03-03-2009, 11:37 AM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
if the wheel bearing is bad enough...you can raise the car in the air and grab the tire at 12 and 6 oclock and if the tire has play in it then its gonna be that side.
as far as the alternator...are you sure thats what the sound is? the only reason i ask is because the serp tentioner makes some pretty mean noises when its going bad also.
edit: as far as the front bumber, you could try Ed Morad (click link)
Old 03-03-2009, 08:25 PM
Now im not sure if it's the front or the rear.. Positive its coming from the passenger side but i hear it worst when i go in reverse turning the wheel to the right backing out or in sharp turns turning right. Makes me wonder if it's not a drive axle or something possibly.. im pretty it's the alternator because the drive belt is fine almost new actually, and it gets worst when you speed up. Easy way is put it in park give it some gas you can hear it squeeling easily and it feels like the end bearing is gone when you play with it.
Also seems like my fan died.. and blower motor or heater core anyways because fan speeds 3-5 work *not so well, 3 feels like 1 and 4 like 3* and 1-2 don't work at all. Also it doesn't blow really warm air until im halfway done my 60km drive to work.. and almost like manual steering when it's colder out.. Great!
Wondering if i shouldn't just take the car in for a safety test and tell them some of the things im experiencing.
Maybe it's just time for a newer car...
Old 03-04-2009, 06:25 AM
wlkjr's Avatar
Cost me $56 to get mine rebuilt about 4 months ago. Had my cousins rebuilt at the same place for an '89 Cavalier and it was about$65. Go figure.
My original had 235,000 miles and wasn't broken, just decided I'd better head it off at the pass. About 130,000 miles later the bearings were making a loud noise.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 03-04-2009, 07:00 AM
wlkjr's Avatar
Repairs are probably less than one month's payment on a new car.
Loosen the belt and spin the alternator pulley by hand and you can hear the bearing grind if that's your problem. I've also had bearings in the water pump make a noise without leaking.
97 Grand Prix GT
01 Duramax/Allison
07 G6 convertible
Old 03-04-2009, 09:13 AM
Did that sounds very squeeky and gets worst the more you spin it
