Old 03-02-2009, 06:20 AM
bulldoggsxr bulldoggsxr is offline
1990 toyota camry electrical problem
Hi all...my 1990 toyota camry driving lightor side light by the headlight, taillight and backup light are stay on all the time. Even when turn the car off and pull the key out and it still not go off. I try to check all the fuses and snoop around still don't know where the problem come from. Anyone know where the problem is and how will I fix it.
Thanks to all in advance..
bd
Old 03-02-2009, 06:35 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1990 toyota camry electrical problem
Welcome to the forum!
If I'm understanding you correctly, pretty much all the lights on the exterior of the car stay on with the exception of the headlights and brake lights, including the reversing/backup lights. What about the instrumentation lights in the dash of the car, do they stay on as well? What happens if you turn on the headlights from the headlight switch, do the backup lights go out?
My best advice would be to move this thread to the Toyota Camry forum and get a wiring diagram for your car, you're likely to need it.
-Rod
Old 03-02-2009, 11:06 AM
Yes all the light stay on after turn on headlight it don't change anything.Just add an extra light to the car.
thank you for your advice
nav.
Old 03-02-2009, 11:09 AM
thank you Rod for the advice. I will get wiring diagram for it,by the way how do i remove the post.
Old 03-02-2009, 01:19 PM
shorod's Avatar
SHO No Mo
You can contact the Engineering/Technical forum moderator and request they move the post.
-Rod
