Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 03-01-2009, 10:24 PM
MuTaLiZeD MuTaLiZeD is offline
Engine Swap
Sry not too sure where to post this so i'll start here. Im looking into buying a 97 eclipse that currently has a blown engine. My question is, whats gonna be a good engine to swap it out with? Yea I know I could always go with the factory re-built replacement but I want a little umph. Any ideas would be MUCHLY appreciated thank you!
Old 03-01-2009, 11:32 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Engine Swap
If you have a GSX/GST you have to stick with the 4g63 (pretty much only option)
If you have a RS/GS you have to stick with the 420a
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 03-02-2009, 10:54 AM
Re: Engine Swap
Im pretty sure its probably an rs/gs. Now I guess my question is what about throwing a turbo into the mix?
Old 03-02-2009, 11:07 AM
david-b's Avatar
Dave is THAT guy
Re: Engine Swap
Turbo will run you at least $1000+ if you build a kit yourself. Premade kits are around $2000+. Look in the members projects section and you'll see my turbo thread which I did myself. It takes time, work, and money and on a stock block can only boost at ~10psi tops. It also depends on the condition of the motor right now too. I would not boost a motor if it's in bad condition. Compression test is the key to that.
75 Monte Carlo
Old 03-02-2009, 11:15 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Engine Swap
Lots of people add turbos to the 420a motor. But like Dave said it cost money and time. If you have to rebuild the motor anyways and plan on boosting it go ahead and get forged pistons and rods. This will only run you another 500 than a regular rebuild but will be able to take the abuse a turbo motor sees.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 03-02-2009, 11:25 AM
Re: Engine Swap
alright cool. I was expecting around that much for the turbo n what not. I will definitely check out your thread! Im hoping to start on it within the next month or two. Any more ideas would be awesome! I'll keep everyone informed on the build when I get there!
Old 03-02-2009, 11:30 AM
david-b's Avatar
Dave is THAT guy
Re: Engine Swap
Do a search around on this site for "420a turbo" and you'll find a lot of useful information from a bunch of members. Let us know if you have nay other questions.
75 Monte Carlo
Old 04-27-2009, 04:29 AM
weave41_82's Avatar
weave41_82 weave41_82 is offline
Re: Engine Swap
here is a question, are there any diff from the 1g 4g63t motors and 2g. other than 6 bolt or 7 bolt. i have a 93 gs right now and was toying with the idea of swaping it for a 4g63t but, if im going to do an engine swap i jus as well do it in a 2g. As there are more mods for the 2g.
Old 04-27-2009, 08:39 AM
david-b's Avatar
Dave is THAT guy
Re: Engine Swap
Main difference is the 6 bolt and 7 bolt motors. Basically still the same thing but with some small differences. You would want to go with a 1G 6-bolt if you're going to do that. The head is made to flow better than than any 2G model.
75 Monte Carlo
Old 04-27-2009, 09:30 AM
Holset powered 420a
Re: Engine Swap
And you wont have to worry about CW.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 04-27-2009, 09:54 AM
steviek's Avatar
steviek steviek is offline
Re: Engine Swap
1g motor the rods are better 2g pistons are better. 1g head bigger intake runners. 2g freer flowing exhaust manifold. 6 bolt no cw. CAS are different through different gens.
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
