Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 03-01-2009, 09:28 PM
Acejas464 Acejas464 is offline
'97 Suburban Brake Problem
I have a '97 Suburban that when you press on the brakes the parking brake light comes on, does anyone know what that means?
Old 03-02-2009, 12:09 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: '97 Suburban Brake Problem
The "parking brake" light is also the brake warning light. It is either low on fluid or its seeing a problem based on what the proportioning valve is doing. I don't recall specifically how these are setup. Start with the basics, a visual inspection for worn out/leaking components will be your next step.
Old 03-02-2009, 06:12 PM
okay thanks,
I will do that but also today when i was driving home from school i noticed that i have to push the brake pedal all the way down just to get it to slow down. Do you think that could be just worn out brake pads?
Old 03-02-2009, 06:38 PM
777stickman 777stickman is offline
As stated by Airjer, your brake system needs a detailed inspection before you wreck your self and/or some one else.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 03-02-2009, 09:16 PM
Reflash Reflash is offline
I'd be WTB U blew a brake line if the light is on and U have a low brake pedal. Take a look at the fluid level in the master cly...I'll bet it's low. If it is...add some more fluid and step on the brake pedal a few times and then look underneath for leaks.
