Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 03-01-2009, 05:27 PM
bronco72 bronco72 is offline
Red face 89 ford bronco oil pan help
is there any other way to pull the oil pan with out pull the motor and taking the bolts out in the oil pan (oil pump)
Old 03-02-2009, 01:23 PM
rhandwor rhandwor is offline
Re: 89 ford bronco oil pan help
Sometimes you can pull the transmission and move the motor enough to pull the pan.
You can pull the bolts on the motor mounts and jack up the motor appx. 4 inches. Put 4x4 under the mounts. Be careful and don't break anything.
You have to remove the bolts for the pan what ever you do. You may have to reach in and unbolt the strainer. I assume you want to clean this item.
Old 03-08-2009, 01:10 AM
jim duckert jim duckert is offline
i have a 88 bronco and replaced the oil pump by lifting the motor 4 inchs
