Old 03-01-2009, 12:26 PM
BIGTEX84's Avatar
BIGTEX84 BIGTEX84 is offline
tranny ground?
in all the write ups for a b16a swap into an 89 std hatch, it says to make sure there is a tranny ground. now when it had the d15 in there it had a wire from near the the clutch cable to the negative batt post, is this the ground wire that is being spoken of? or is there suppost to be a ground to the frame as well from the tranny? sort of confusing because they say this messes alot of people up. if it is the cable to the negative batt cable from the tranny, how can this mess u up seeing as you have to have a cable to the neg batt terminal, are people just forgetting they have 2 batt terminals?? or is it a separate ground??
Hey, if you are looking for a good deal on a motor swap, with fast shipping and great customer service, Ive got just the place for you. . . . . . . . TO STAY AWAY FROM!!!!! WWW.OSAKAJDMMOTORS.COM=BULL$H!T!!!!
Old 03-01-2009, 06:24 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: tranny ground?
Thats the tranny ground, there is also one on the valve cover and one on the thermostat..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 03-01-2009, 07:01 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: tranny ground?
And the OE negative battery cable grounds to the frame and then over to the transmission
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 03-02-2009, 12:54 AM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: tranny ground?
Make it easy - go on Ebay, get a ground wire kit, and use it.
There are 8 wires, total -
1. Battery to Head
2. Battery to Block
3. Battery to Frame
4. Battery to etc.
5. Battery to etc.
6. Battery to etc.
7. Battery to etc.
8. Battery to etc.
Often times, those extras are used for accessories, but can be used on different parts of the engine assembly, or any way you see fit.
Replacing the grounds and ensuring proper contact is one of the best ways to gain 1 or 2 MPG and gain driveability. It also makes your alternator not have to work as hard, due to less resistance in the electrical system.
Clean/repair your grounds any time you see a problem with them. I always recommend replacing the OEM grounds with at least 8g wire and soldered lug ends. Use Amp wire... it comes in colors and looks cool.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 03-02-2009, 05:35 PM
BIGTEX84's Avatar
Re: tranny ground?
thanxx guys guess someone rigged mine to run from neg batt term straight to the tranny.
