Old 03-01-2009, 09:33 AM
glc4122 glc4122 is offline
1997 pontiac gp se strut removal help
is there a online illustration on removing and installing front struts?
Old 03-01-2009, 10:56 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1997 pontiac gp se strut removal help
Out of curiosity what brand struts do plan on installing?
See the link below for a tech procedure with pics. Good luck!
Click here
Timeslip 08/12/06
AF Community Guidelines
Old 03-01-2009, 03:32 PM
thanks for the information B Naylor probably the cheapest i can find.
Old 03-01-2009, 08:30 PM
rickisrad rickisrad is offline
read up on the different problems we have had on the strut/ strut plates. Use only a GM or KYB mount/ bearing plate and most of us here would recommend the KYB GR 2 struts. You can find them cheap from some of the performance sites.
2004 GRAND PRIX GTP COMP G. VIN 4 :
OVERKILL CUSTOM PCM, WIZAIR CAI, ZZP TRAILING ARMS, W BODY STORE LATERAL ARMS, ALL POLY/SOLID MOUNTS, STB F&R, ZZP RACE TRANS, ALT REWIRE & VOLTAGE BSTR, 180 STAT, NGK TR6, MPS with 3.4 PULLEY, PACESETTER HEADERS, 1.8 ROLLER ROCKERS, FP REWIRE,ZZP COILS/WIRES, TB SPACER, D&S ROTORS, INTERCEPTOR SCAN GAUGE, CUSTOM STAINLESS 2.5 INCH CAT BACK EXHAUST.
2004 Honda Odyssey EX-L
Old 03-02-2009, 10:37 AM
BNaylor's Avatar
Cheaper is not better and you get what you pay for. But the KYB Excel G/GR2 or the OE GM struts are the best bet based on my experiences. The problem I have with the cheaper aftermarkets like the Monroes or Gabriels is they do not last or you get issues with the upper strut mounts after installation. You will be lucky to get 40K miles out of them. At least you can get 70K miles or better out of the GM struts.
Timeslip 08/12/06
