Go Back   Automotive Forums Car Chat > Kia > Sephia
Old 02-28-2009, 09:11 PM
bcm811 bcm811 is offline
2000 Kia Sephia misfiring randomnly
Hello, I own a 2000 Kia Sephia and it has been running beautifully and getting great gas mileage until just recently. I will say after this problem has occured I have changed the spark plugs and bought a new coil pack for cylinders 2 & 3.
The car will run fine for a little while and then randomnly start misfiring extremely bad. I have to do all I can to keep it from stalling out. It will not misfire constantly but will misfire for 5-10 minutes and then straighten out for awhile. I am not sure what is going on but I have checked all vacuum lines and air intake and all of them seem to be in working order. I have scanned the ECU codes and they have come out P300 P302 P303. Basically the misfire codes for cylinders 2 and 3. Has anyone had experience with this before? Any suggestions would be GREATLY appreciated. I'm going crazy here.
Old 03-23-2009, 03:24 PM
denisond3 denisond3 is offline
Re: 2000 Kia Sephia misfiring randomnly
Here are my guesses: First - do a compression check on all cylinders. If you have bad compression, you can have misfiring. Second - Of course have a look at the color of the plugs. All should be dry and a sort of beige color. Could it be bad spark plug wires? (I dont even know of Kia's have plug wires for 2 & 3.
Next; it could be a couple of fuel injectors that are partly clogged. The only method I know for diagnosis is to swap the cyl 1 & 4 injectors with the 2& 3 injectors, and see if the codes change to misfiring on 1 & 4. Then you could assume its an injector problem. I might just replace the injectors with 'rebuilts'. When injectors for my sister in-law's Toyota Avalon were about $100 locally, I got a rebuilt pair from a guy on ebay for about $40 (including the 'core' charge & shipping).
If the misfiring stays on cylinders #2 and #3, I would think it could be wiring harness of PCM problem.
Old 10-19-2009, 01:43 PM
traffic_tom's Avatar
traffic_tom traffic_tom is offline
I am having the same problem and the mechanic said that the plug wires are arcing?
Old 04-13-2010, 03:17 PM
mark_gober mark_gober is offline
I'd check your spark plug wires. I had a very similar problem. (with blinking engine light). I pulled out the #1 spark plug wire and there were very small holes that had penetrated through the spark plug boot and it was arcing to the block. I replaced the wires and it's been running perfectly ever since. Good luck.
Old 04-13-2010, 03:23 PM
