Old 02-28-2009, 06:14 PM
mari517 mari517 is offline
Unhappy just did the mains
just did the mains and still no oil pressure
Old 02-28-2009, 11:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: just did the mains
Hmmm, not sure if you are asking a question or making a statement, or both.
Are you relying on the gauge in the instrument cluster to determine if you have pressure or not, or are you using a mechanical guage where the oil switch connects? Do you really have no pressure, or just low pressure? I assume you are referring to main crankshaft bearings. Did you change them out because you had low oil pressure? Which year of Taurus and which engine does it have?
-Rod
Old 03-02-2009, 10:09 AM
s1120 s1120 is offline
I had to do the lowerend on my 96 Windstar with a 3.8L in it. The mains were pretty bad, the the rod bearings were the worse. Did you check them???
