Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-28-2009, 04:56 PM
schram1124 schram1124 is offline
abs problem
hi I'm new here and i got a 1996 cutlass supreme and the abs light is on what should i look at first thanks for the help
Old 03-01-2009, 08:27 AM
Reflash Reflash is offline
Re: abs problem
Speed sensors and related wiring...but first U need to scan for codes to see what the fault is. Short of doing that is shooting from the hip.
Those early W bodies were known for rear speed sensor and wiring problems...fwiw
Old 03-01-2009, 06:29 PM
Re: abs problem
thanks i scaned to day no codes for the abs ! just egr and misfire on c #1
Old 03-01-2009, 09:23 PM
duke350 duke350 is offline
Re: abs problem
You need to use an abs capable scanner. A run of the mill obdII scanner will not read abs codes. Actron has one for about $200 now. If the light is on, there is a code.
