Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 02-28-2009, 08:15 AM
dghawk dghawk is offline
1993 98 glove box lamp wiring diagram needed
Hi all!! I have a 1993 98 and the glove box lamp quit working. The bulb is ok and I cannot find a fuse for that circuit. Anyone have a wiring diagram for that circuit?? Any and all help is appreciated!! Thanks. Sincerely, Dave.
03 Chrys 300M Special
93 Olds 98
96 Yamaha XV1100S
Old 03-01-2009, 08:00 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 1993 98 glove box lamp wiring diagram needed
Do you have power to the switch?
Old 03-04-2009, 01:26 AM
I don't know if there is power to the switch, I can't find it. Olds built this area like Fort Knox - all sorts of padding, brackets, and shields. The switch is not readily visible. Do you have a diagram of where the switch is? Which fuse supplies power to this circuit? Neither the fuse block designation nor the owners manual specifies which fuse supplies the glove box light. Thanks for your help!! Sincerely, Dave.
93 Olds 98
96 Yamaha XV1100S
Old 03-04-2009, 08:26 AM
brcidd's Avatar
brcidd brcidd is offline
My source doesn't say exactly either- try fuse number 11 a 15 amp- same circuit as cigarette lighter, and power antenna- do those work?
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 03-05-2009, 01:45 AM
Thanks for your reply!! Yes, the cigarette lighter and the power antenna both operate. The courtesy lamps operate also. Basically, this is the only thing that does NOT work on the car. I will look at it again this weekend (no time today or Friday) and I will post results. If anyone has more suggestions, please post them - I appreciate all the help I can get! Sincerely, Dave.
93 Olds 98
96 Yamaha XV1100S
Old 03-08-2009, 08:45 AM
Problem solved!! Valuable lesson - know how something works before you condemn it!! Apparently, the glovebox lamp is only supposed to illuminate when the glovebox is open with the key in RUN. It will not illuminate like most other vehicles by just opening the glovebox, even with no key in the ignition.
93 Olds 98
96 Yamaha XV1100S
