Old 02-27-2009, 08:36 PM
billypk3 billypk3 is offline
2000 s10 extreme vibrations
i have an s10 that came with a vibration at highway speeds was told i needed to replace the drvieshaft so i took it to a place that just does driveshafts was told i only needed the rear piece that he had a conversion to a single u joint that works well after install the vibration at highway speeds is gone now i have a vibration from 0 to 20 much harder than original one was told too shim the rear 2 degrees thats been done vib still there any ideas where to go
Old 02-28-2009, 08:57 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 s10 extreme vibrations
Has it been lowered or raised?
Jack it up and put stands under axel.
Start engine put in gear and speed up slow from 0 up to bad shake.
Then remove tires and wheels and bolt on drums /rotors and speed up again and see it still shakes.
Was drive shaft timed up? with U joints timed?
Was it balanced when done?
MT
