Old 02-27-2009, 08:28 PM
liquidmxz liquidmxz is offline
Object found in engine,..can anyone ID this piece?
2000 cavalier Z24
manual
115,000 miles
Ok so last week I am driving to class and I heard a bang/clank.
I brushed it off and figured i hit something on the road. My music was up so I could not hear any effects right off the bat. When I was leaving class I started my engine and immediately heard a loud clanking/ticking noise coming from the engine.
I ripped into the engine and all 4 cylinders are around 200-210 psi.
I did find this piece of metal in the section of the engine right above the valves but below the camshaft housing. I spotted it by luck when I was looking down the fuel injector opening and was able to pull it out with a magnet.
I am not sure this is what was causing the noise, it is not banged up/or scratched a whole lot. however, I do not know where this came from.
What in the world is this from?
thanks!
Note:
- clicking/clanking Noise is independent of whether or not the car is IN or OUT of gear
- Noise does increase as engine RPMS increase.
image below or view it at the following address
http://crucialfactor.com/object_engine.jpg
Old 02-28-2009, 09:13 AM
Blue Bowtie's Avatar
Registered Offender
Re: Object found in engine,..can anyone ID this piece?
What engine?
Old 02-28-2009, 09:23 AM
Registered Offender
It appears to be about the size of an axle from the roller on a lifter/cam follower, but depending upon your engine, that may or may not apply.
Old 02-28-2009, 10:19 AM
sorry, the engine is the 2.4 ltr
Old 02-28-2009, 07:05 PM
J-Ri's Avatar
J-Ri J-Ri is offline
That's a 1993 Lincoln head penny! What's that doing in your engine?
Seriously though, it looks like the inner part of the tappet (the thing that transfers motion from the cam to the valve) How it would get to the valve head.... I don't really know, but there'd have to be a hole the size of the in the head to let it get to where it was (I think, I've only been inside one of these engines once). Since it was resting on the valve, you know that valve isn't opening, or it would have gone down into the cylinder. Rotate the engine by hand and confirm that valve isn't opening.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 03-01-2009, 07:16 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
I'm going to have to agree here.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 03-01-2009, 09:07 PM
It appears to be about the size of an axle from the roller on a lifter/cam follower,......
If this is the case,.... what impact does it have if i drive without this piece in the car? the car starts up and runs ok with out it (with the exception of the ticking sound)
I was able to remove the cam and lifters while the engine remained in the car,...can i replace this "roller" , or is it easier to buy a new head assembly? Am I able to replace the head assembly without pulling the engine?
Old 03-03-2009, 05:24 PM
J-Ri's Avatar
Is the "piston" in this picture what you two are refering to?
[link]http://www.nuvision.ndo.co.uk/tappet1.jpg[/link]
I don't remember there being any rollers in this engine?
Old 03-03-2009, 05:31 PM
CoolasIce CoolasIce is offline
It could also be part of a one way check valve. Maybe it's an extra one from the factory. It could happen.
Old 03-05-2009, 09:53 AM
hah, no that is definetely NOT a piston.
JI don't remember there being any rollers in this engine?
I agree, this is the dual over head cam I am almost sure this piece is not from my engine. I had work done on it and I think it was placed in there through my intake,..accidently or not (its a long story).
Besides the fact, the engine still makes noise. What are the chances that the bearings where the connecting rods meet the crankshaft are worn thus the source of knocking? I should mention there WAS a severe lack of oil for an extended period of time before this "ticking/knocking" started lol.
Am I able to pull the oil pan off to check this?
Old 03-05-2009, 11:04 AM
Lifted GMT-360!
With that statement said, I would be willing to say your main bearings are toast. Not only is that motor known for spinning main bearings, but it has an already poor oiling system/pump.
Old 03-06-2009, 05:54 PM
any suggestions on how to confirm if this is the problem? I take it this is requires an engine pull to fix? Does pulling the oil pan allow me to verify any bearings that may need replacing on the crankshaft?
thanks!
Old 03-08-2009, 01:19 AM
J-Ri's Avatar
definetely? You mean definitely? Anyway, if you look up "piston", you'll find they can be more than the big aluminum thing at the top of the connecting rod. (I'll teach you to laugh at me ) The center part of the tappet was referred to as the piston on the page that image was from (which I realize now was not labeled in the picture, and that's not from the 2.4, just a representation). Also, the valves open far enough that a piece that small would have fallen into the cylinder, not rested on top of a valve, which means that one valve is not opening, which is why I thought it was the piston out of the tappet.
How long was the engine run low on oil, and how low was it? I would expect a knocking to start while the engine was low on oil, not after... which is not to say that adding oil would put metal back on the bearings. Since you describe the noise as a ticking/knocking, it would also lead me to think something in the valvetrain. Ticking usually points to the valvetrain.
Old 03-08-2009, 07:32 PM
The piece you are referring to in the center of the tappet is much larger than the piece I found. I actually thought that may have came from that so I pulled one out and sure enough the piece I had found was much smaller in diameter.
I'm pretty sure all the valves are indeed opening. There is no way for the valve not to open with the cam in normal operation without some serious damage to the pistons.
Here's the skinny on the oil issue, 10-15k miles since the previous oil change, You are correct, the noise DID start happening when the car was low on oil. I tore into the engine, drained the oil and found approx 1-2 quarts.
I know I obviously neglected the car, I just have been extremely busy and was waiting till break to change the oil, I suppose I should have at least checked the level,...oh well.
I'm debating on pulling the oil pan next weekend to see if I can confirm anything, otherwise I may just end up getting rid of the car next week.
Old 11-11-2009, 06:39 PM
534BC 534BC is offline
looks like a dowel pin to me.
