Old 02-27-2009, 11:42 AM
90sBeater 90sBeater is offline
90s rear drum leak alts
Hey all,
The cylinder has has lost it's pressure and greased up the drum. It's shot and needs to be replaced completely. (300$) But like the rest of the planet, I R broke. What alternatives are there? Can I clamp the line? Disconnect it from the MC? I can sign a waiver for info. ;]
Old 02-27-2009, 12:48 PM
rustbucket rustbucket is offline
Re: 90s rear drum leak alts
The part is less than $20, an its not much more complicated than a brake job( as long as it isnt rusted too bad)
Daily Driver: 2008 Chevy Impala - 30000 mi
Others:1993 Chevy S10 - 85000 mi, 2000 Saturn SL2, 1987 Buick Lesabre RIP, 1999 Buick Lesabre
Old 02-27-2009, 01:49 PM
C man C man is offline
Autozone has a cylinder for $13 and if you want to get real cheap you can get the rebuild kit for about $4. but you will need new shoes also.
Clamping the brake line? Doesn't sound like a good idea at all. Just refill the with brake fluid very often. But you need to get it done fast because it will turn from a small leak to a large leak very fast. Did all the brake fluid drain out before u discoverd this problem. If so you could have air in the lines on top of the leaking cylinder. I wouldn't be suprised if it was the rear cylinder on the passenger side that was leaking.
$300, Somebody trying to make a arm and leg off of you.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 02-27-2009, 02:27 PM
big white bufflo big white bufflo is offline
replace the cly spray the shoes with breakkleen sand them call it a day till you can get new shoes
Old 02-27-2009, 03:10 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
One set of shoes $12.99 - one wheel cylinder $12.99 - 45 min labor to install both, results "priceless"!
Old 03-03-2009, 08:34 AM
Thanks for the Help, Ya'll.
One place was trying to charge 150.00 in labor..
(closed)
