Old 02-26-2009, 08:29 PM
seanjjem seanjjem is offline
replaced alot, still won't start
i have a 2000 gtp with 170,000 miles. last week the car died, the power steering went out, and still will not start. Still had all power though. I replaced the fuel pump, the MAF sensor and a few other things, and it still will not start. Any ideas???
Old 02-26-2009, 11:17 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: replaced alot, still won't start
Welcome to AF.
Did it stall at idle only or any specific speed? What other conditions? Any lights on at the instrument panel like TRAC OFF when car dies? Even with the new fuel pump have you verified the fuel pressure at the front fuel rail is in specs? 48-55 psi.
Timeslip 08/12/06
AF Community Guidelines
Old 02-27-2009, 07:27 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
A little more specific info would really help. In addition to Bob's questions, is your service engine soon light on; by not start, do you mean the starter does not turn the engine over, or do you mean the starter turns the engine, it just doesn't start?
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-27-2009, 10:11 AM
Fortune50 Fortune50 is offline
Yep, we need more info, what were the "few other things" done? Have you looked over all the fuses and make sure none are blown? Does the tach move when cranking over the engine? If not, probably the crank sensor has failed. If the tach moves, verify if it's a fueling problem by spraying t-body cleaner into a vacuum line and see if it runs for a bit or not.
If still no change, then verify spark in all cylinders. If there's spark then you'll need to get the PCM scanned and see if there are any codes stored and even better if you can look at the data stream.
Beyond these tests, you'll need to verify cylinder compression and perhaps timing on cyl #1 shining a timing light on the balancer (if the timing chain has an issue).
Let us know what you find out or if you get if fixed .
1995 Toyota Camry LE beater sedan
1999 Toyota Camry XLE "less" of a beater sedan
1997 Pontiac Grand Prix GTP coupe (SOLD)
1999 Ford Taurus SE 24v (SOLD).
Family's cars:
1999 Mercury Sable LS wagon 24v.
1999 Ford Taurus SHO 32v.
2002 Honda Civic LX sedan.
