Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-26-2009, 07:32 PM
mike561 mike561 is offline
Wiper switch
Im trying to replace the wiper switch but i cant figure out how to remove the headlight knob, i diddnt wanna try to pull it off and end up ripping out the headlight switch. keep in mind i have an '83 so the wiper switch is on the dash rather then the steering column.
2006 Chevy Cobalt LS
Old 02-26-2009, 08:32 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
Re: Wiper switch
I'm pretty sure its the kind of knob that just pulls straight off with like a crescent or half moon shape end. Just to be safe i'd turn the lights on so you can clamp a pair of vice grips on the shaft to make sure you don't rip out the switch. So if you've taken off the (original) radio knobs before, i think it should be similar to that. There may be some sort of locktite in it however so like i said use the vice grips to keep from ruining the switch.
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 02-26-2009, 08:57 PM
Re: Wiper switch
yeah the knob is on there, i gave it a firm tug and it wont budge. i would try the vise grips but i dont wanna bend the headlamp switch rod or mess up the knob, though i may need another headlamp switch anyway cause if i try to rotate the knob to dim the dash lights they flicker on and off.
Old 02-27-2009, 01:49 PM
soulmonger soulmonger is offline
Re: Wiper switch
If its anything like my old bonneville there is probably a clamp on the inside of the knob holding it to the shaft. Rotate the knob and look behind it for a small peice of metal sticking out just a tiny bit. Use a flathead screwdrive to push that peice of metal down while pulling on the knob and it should come off.
Old 02-27-2009, 05:23 PM
bhw33191's Avatar
Re: Wiper switch
Oh yeah mine flicker too when i do that. I think its just because the component that dims the lights is rusty. But i don't think its because its breaking or anything. If you could take it apart it might be as easy as some wd-40/grease or something.
Old 02-27-2009, 05:29 PM
Re: Wiper switch
thats what i was thinking too, the contacts are probably just rusty. ill look for that little clip though too
Old 03-01-2009, 01:34 PM
Blue Bowtie's Avatar
Registered Offender
Re: Wiper switch
On the side of the light switch behind the dash is a spring-loaded push button. Turn the headlights on, reach under the dash, and depress the button, The light switch knob will pull out easily. Remove the escutcheon nut and switch assembly.
Light switches were like this for about 40 years. Then accountants took over from the engineers and decided that having everything on the steering column was a better idea (from a cost perspective).
Old 03-01-2009, 01:51 PM
Re: Wiper switch
that sounds more like it would work, ill give that a try, thanks blue bowtie.
Old 03-01-2009, 06:52 PM
Registered Offender
Re: Wiper switch
This might help:
Knob Release
