Old 02-26-2009, 01:10 PM
4xbill 4xbill is offline
ABS Light?
I have a 2000 Z71 with over 110,000 miles. Just today while driving the ABS light came on and stayed on. When I returned home I hooked up my scanner but there were no DTC's listed. Anyone have any ideas what this could be?
Thanks in advance for any help.
Old 02-26-2009, 04:58 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Re: ABS Light?
can your scanner access the ABS module?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 02-26-2009, 07:25 PM
Re: ABS Light?
Update: Okay, since my last posting, I was heading out again and notice an intermittent squeal coming from under the truck. Luckily I wasn't quite to the end of my street so I turned around and crawled home at about 10 mph. Once there I put the truck up on a jack and found about an inch of wiggle in the front passenger side wheel. So it turns out it's the wheel bearing and I'm assuming that's what triggered my ABS light.
My new question would be: Is it just the bearing that get's replaced or is it the whole Bearing/Hub assmbly? And, if I'm replacing the passenger side should I go ahead and replace the other side as well?
Old 02-26-2009, 08:43 PM
777stickman 777stickman is offline
Re: ABS Light?
Definitely replace both while you're there.
http://www.automotiveforums.com/vbul...d.php?t=943679
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-27-2009, 07:58 AM
j cAT j cAT is offline
Re: ABS Light?
since the ABS Lt was on I suspect that the speed sensor on that side will need replacing...before installing the rotor spin the hub and measure for a voltage of 300-500MV ac....at the sensor connector,,,,then compare with the good side if lower than 300mv this would indicate problems ...
Old 02-27-2009, 06:08 PM
kahjdh's Avatar
Re: ABS Light?
Hub assm. comes with new sensor.
Current Cars:
Past Cars:
Old 03-04-2009, 11:23 AM
Houston54 Houston54 is offline
Re: ABS Light?
This is a common problem on the Chevy/GMC truck platforms. I had the same issue with my 03 Suburban.
The fix is hard to accept because it is so simple.
There is a ground wire that is bolted to the top rear of the engine block on the passenger side. The ground connection becomes compromised due to rust, dirt or grease over time.
Take off the engine cover, reach back to locate where the bolted connection is and twist the lug to ensure the ground is firm. It may be necessary to unbolt the connection and clean the surfaces and re-install.
This should solve your ABS dash light problem. It also resolves many other strange electrical issues owners have been having with the pickups and SUVs.
It sounds unlikely to be the fix but try it before tossing money at the dealer or mechanic. If it works you can toss the money to me.
Old 03-04-2009, 10:08 PM
lluedecke lluedecke is offline
Re: ABS Light?
My ABS light and parking brake light both came on and stayed on while driving. Took it to local shop and they ran the codes. They re-grounded the wire as in the previous post and started the truck to find out this did nothing. They found out that it is the ABS module that is bad.
2000 Silverado z71, 3in. body lift, K & N fipk, Flowmaster duals, 305/70 BFG's, Hella 500's
Old 03-05-2009, 07:59 AM
Re: ABS Light?
If you have a problem start your own posting....
This was for ABS Lt on....only...not your issues...
