Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Bolt on Parts
Old 02-26-2009, 12:15 AM
steviek's Avatar
steviek steviek is offline
Methanol kit install how should I run lines
Hey guys here is my predicament. I really want to install my meth kit with the bottle in the trunk cause its empty and there is no room anywhere else. Now the only real question is where should I run the lines. The one obvious option is under the car but it is rubber hose that may get damaged easily when exposed under the car (even with the protective cover maybe) and the other option is through the interior but then I'm sorta concerned about the hose getting pinched by either someone inadvertently stepping on it or what not. what would you guys do any experience?
Input welcome!
FP 18g turbo e3 o2 & mani, 3" exhaust, , 7 bolt, wiseco/eagle, walbro 255hp re-wired, Aeromotive FPR, FIC 1150cc, injen intake, greddy RS, aem wideband, turbo xs mbc, act 2600 clutch sprung 6 puck, BC 272's, dsmlink v2.5, ETS FMIC, Devils Own, JMF SMIM.
18 Inch chrome rims
In closet AEM Fuel Rail, SS Lines,
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
http://i83.photobucket.com/albums/j2...y/DSC00461.jpg
Old 02-26-2009, 06:39 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: Methanol kit install how should I run lines
I think either one you would be fine. I would run the line along side of your fuel lines, just zip tie them together and you would be fine. But if your concerned with that run it throught the interior. I would probably run it under the carpet right in the corner where the metal folds up to meet the door. No one will step there
I plan on getthing meth soon so I want some results posted up
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-26-2009, 12:44 PM
steviek's Avatar
I will def post the results so you would do them with the fuel lines eh?
Thats a good idea I am looking forward to the install I just need one day where it is decently warm outside and it is in!
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-26-2009, 01:25 PM
Holset powered 420a
I want logs of air temps and how much more timing you can run. Sh1t, the 4g63 logs air temps at the MAF doesn't it?
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-26-2009, 02:01 PM
steviek's Avatar
Yea i was just going to say that. Its not gonna change my air temps until after the maf. PLus if you saw my air temps and thought they were at the manifold you would prolly cry cause my IAT are normally just like 10 degrees over ambient cause of my air dam.
Timing I can show you KNock and airflow also
Effectively these are much more important anyways
Also anyone know what target A/F I should aim for with 100% meth on a M14 nozzle?
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-26-2009, 05:51 PM
Holset powered 420a
You know that meth doesn't offer hardly any cooling to the air charge. Its mainly the water that cools the charge down. But most people go for 12.0 I believe. There is a good thread on tuners you may want to check out.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-26-2009, 08:03 PM
steviek's Avatar
yea i know the cooling is more of a side benefit
I think i got this under control you guys will get a nice update soon just as soon as the devils own sends my missing relay.
18 Inch chrome rims
1997 TSI AWD
Diamonds Are 4Ever
12.7 @ 107
Old 02-26-2009, 10:32 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
It's been 3 years sence I installed my Meth kit. Becasue all Surflow pumps are gravity fed I mounted mine in the spare/tire bracket and mounted my 1 gallon tank on the back of my rear-driverside seat. I can't really tell whats in the bags but I recomend at least an inline screen filter and LED float level (mounted on a-pillar under boost gauge).
As for the lines I wouldn't run them under the car, they are not durable enought to withstand the dabree and crazy temps up north. I ran min dirrectly under the center console and though the firewall on the passenger side. You should see a HUGE change with the M14, I ran an M5 (way to small on 16g) then swithed to an M7 (.5deg knock reduction) then to an M10 where it gave me the best results. I was seeing 2deg less knock, and 2 degee better timing advance.
I don't know if you'll ever decide to run a 3in GM maf, but make sure to possition the M14 nozzle a far away as hummanly possable from that thing. I had mine halfwa down the upper intercooler pipe with the M10 4 inches away from the TB elbow and I was still getting residual moister in my MAF that compleaty fucked my day up.
DSM geek
