Old 02-25-2009, 08:22 PM
hbrammer hbrammer is offline
trouble codes
Hey guys,I need some help-I pulled the following codes today and need someone to point me in the right direction as to what i need to test/fix/replace.
181 Fuel system at rich adaptive limit at partial throttle/system lean
186 Fault in injector pulse width/high
Car is a 93 escort.1.9
thanks in advance
Old 02-26-2009, 03:38 AM
mightymoose_22's Avatar
mightymoose_22 mightymoose_22 is offline
Re: trouble codes
Due to the injector code I would start by running a good cleaner through the fuel system... maybe you have a stuck one. With the engine running you can also listen with a stethoscope for clicking inside the injector... make sure they are actually working, or working normally compared to the others.
