Go Back   Automotive Forums Car Chat > Chevrolet > Express | G Van
Old 02-25-2009, 06:57 PM
Doiturselfer69 Doiturselfer69 is offline
'97 Chevy Van Express - Won't Start
I have a 1997 Chevy Van Express, 3500, w/ 5.7 Liter engine. According to my wife it was moving along fine then it just died on her, she coasted to a stop and it wouldn’t start back up. It turns over good battery and starter work fine. I tried some starting fluid no luck, then I poured some gas in the throttle body no luck there either.
What puzzles me is that it wouldn’t even fart or try to start, I’ve always gotten a sputter or something when I’ve tried starter fluid or gas this time nothing. I don’t smell any gas when I pump the gas peddle either also, the fuel pump is in the gas tank correct?
Any help would be Greatly Appreciated!
Marty
Old 02-26-2009, 09:11 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: '97 Chevy Van Express - Won't Start
Marty
Yes fuel pump is in the gas tank.
If no start always check for good hot blue spark to all spark plugs and for spark out of coil.
If good spark check the fuel pressure for up to par.
Can you hear fuel pump running?
Should have 60/66 lbs and 64-65 lbs cold cranking.
Report back on spark and fuel pressure.
Any check engine lights or codes?
What is mileage and last tune up history?
Have you check all fuses for 12 volts both sides?
MT
Old 11-16-2011, 10:09 AM
Ikeepitreelz Ikeepitreelz is offline
old topic i know..but if you poured gas down the throttle body not the slightest fire up means no spark...sounds like an ignition issue.
Old 11-17-2011, 06:40 AM
MT-2500's Avatar
AF - Advisor
Pouring gas down the TBI or starter fluid is not the safe way to test it.
MT
Old 11-17-2011, 06:59 AM
Talking Re: '97 Chevy Van Express - Won't Start
Didnt advice to test it that way, HE poured gas down the throttle body, not all of us have the correct tools to follow proper procedure and not all if us can afford dealer or local mehcanics....
Old 11-17-2011, 07:46 AM
MT-2500's Avatar
AF - Advisor
I did not say you did.
Just advised that is not a safe procedure.
MT
Last edited by shorod; 08-30-2012 at 12:59 PM. Reason: Removed some potentially offensive comments that were not providing value.
