Old 02-25-2009, 06:54 PM
smiley24 smiley24 is offline
98 blazer new problem lol
ok while i was having the map sensor replaced i believe some plastic or some trash or something got n the hole that the sensor fits n 2 because i can hear something rattling around when i start it. well i havent tried starting it againg and i wonder if thats what has happened and could i have done any damage?
Old 02-26-2009, 08:59 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 blazer new problem lol
Map sensors do not rattle.
What engine and mileage and why was map sensor replaced,
Any codes or check engine lights.
Start it up and look and see and feel for where the rattle is coming from.
What kind of rattle sound marbles or metal or something lose?
MT
Old 02-26-2009, 10:05 AM
no the hole that part of the map sensor plugs into is where i think something fell in. the sound is like when your pop corn is done popping n u have that 1 kernal that didnt pop bouncing around every now n then is the sound it makes
Old 02-26-2009, 10:09 AM
and the sound is coming from the under thortel body area
Old 02-26-2009, 10:13 AM
MT-2500's Avatar
AF - Advisor
Map sensor or hole will not make a sound like that.
But to make sure you could Pull the map and see if it has a rattle/pop which would be real strange.
Have a look around and find out and pinpoint where the noise is coming from.
You did not answer why it was replaced to start with or.
WHAT ENGINE OR IF ANY CODES.
We can not be much help unless you give us needed info.
GOOD LUCK
MT
Old 02-26-2009, 10:17 AM
it was replaced because when we were replacing the fuel pressure regulator it was broken when we were taking stuff off 2 get 2 the regulator
Old 02-26-2009, 10:25 AM
it has the 4.3l v6
Old 02-27-2009, 09:38 AM
travtug123 travtug123 is offline
it has the 4.3l v6
If something has fell in the whole you will have to take the intake off of it to get it out. You do not want to replace the egr value next.
Kim T
